: Help with wildwhl mod please ASAP
01-17-07, 03:17 PM
Im in the middle of the first spring rear passenger. Im currently performing the wildwhl spacer mod an am confused because I have so many spacers!!! I have 4 large hard spacers, 4 medium hard spacers, 2 soft large inner hole spacers, and 4 soft small inner hole spacers. What should the order be of the spacers. I am looking at the faq but cannot figure it out. Thanks
01-18-07, 01:06 AM
Hope I'm not too late.
The concept is as follows:
The smallest spacers (about 3/4" diameter from memory) go inside the top shock mount where the old (factory) spacer used to interlock. The large diameter spacers should have two different inside diameters. The smaller ID versions go below the shock mount, and the larger above the shock mount. If you are going for maximum slam, just install one of the soft, small ID *washers* below the shock mount and as many of the others as will fit above the shock mount.
The idea is that the amount of adjustment is "adjustable".
Hope this helps...
