smooththg6969
01-16-07, 08:37 PM
well I was getting excited because My northstar is was going together quite well. I'm trying to put it back in this weekend, but when I went to put the timing cover back on I noticed it was different than the original. the original has the bottom edge cut off for what seems to be a mounting hole for the right engine mount. but the replacement block doesn't have this.
here is a pic of the replacement block cover
http://i125.photobucket.com/albums/p70/smooththg69/Image040.jpg
you can see the bottom edge is rounded at the corner. now here is a pic with me holding the original timing cover in front of the the replacement.
http://i125.photobucket.com/albums/p70/smooththg69/Image041.jpg
now do you see what i mean?
heres the mount that supposed to go there from the fsm
http://i125.photobucket.com/albums/p70/smooththg69/84939393.gif
there are three other bolts that hold the mount in place I think I can put it on there with a little massaging of the timing cover but I'm thinking about the stress that would be put on the other bolts. I know the side mounts have the least amount of stress put on them But I don't know if I should trust this solution or not. any suggestions?
