View Full Version : 5.7 Liter Diesel trans problem
tedasaurus
01-15-07, 09:01 PM
Will not shift on its own. Just hangs in any gear. It will shift from 1 to 3rd if you manually shift it using the column. Anyone have a clue?
caddyman2005
01-21-07, 06:33 PM
Check for vacuum at the vacuum modulator. check for vacuum leaks from the assist pump to the accessorys. does the a/c blow at the right vents. the assist pump is where the distributor would be in a gas engine (center rear)
carnut
01-23-07, 08:04 PM
Could also be a stripped plastic governor gear. Or the weights on the governor stuck. Get a manual that shows how to access the governor. Its accessed from the trans case, located close to the tailshaft under a tin cover held in place with a snap ring.
awadecki
04-28-07, 09:42 PM
What car is this? I don't believe it's any that you've listed. The first thing I'd check is the TV cable to make sure it's adjusted properly. It'll hang up on shifts like this is it's way out of whack.
