: 93 Caddy Fleetwood Radio Dash Pad
01-15-07, 02:10 PM
Just wondering if anyone can help me with how to take off the radio dash pad. I dont want to brake anything. is there bolts or screws holding it in. please help.
01-15-07, 09:02 PM
2 screws upward behind the 2 a/c vents, the vents must come out, then 2 screws on the sides next to the mirror knob and a/c controls...1 on the left and 1 on the right
01-16-07, 09:41 PM
77-92 will be different than the 93-96
If this is a 93 or newer:
there is a wood strip, using a flat blade screwdriver, carefully pry away from the dash. From there you will see some hex bolts (small size) this will unfasten the AC control and the faceplate (you only need to remove the ones for the AC control unit)
Once you have the appropriate hex bolts removed for the face plate, this can be pulled off starting by pulling the top, the pull the bottom (which is held in with clips).
