: Question about doing trans fluid change via trans cooler lines.
Gwokable
01-15-07, 01:24 AM
How should I go about doing a transmission fluid change?
I know how to do a filter and gasket replacement. That's simple enough. But that only gets 4 quarts of 12 quarts of fluid, and I want to change out all 12 quarts, which means I need another method.
Now the other method I'v heard talked of on this board is as fallows. I'm wondering if anyone's done it and if so, how successful they were.
*Pull trans pan, install new filter and O-Ring, check swarf, reseal pan.
*Fill tranny up with fluid and cleaner.
*Run car in nuetral to recirulate fluiid as directions state.
*Pull trans cooler lines off of the radiator, get 5/8ths inch hoses and clamps. Install hoses onto trans cooler lines.
*Run bottom return line to the bucket filled with 16-20 quarts new fluid. Make sure to pump fluid into the hose before turning the car on to reduce air going into the trans.
*Run top output line to another bucket.
*Turn car on, watch buckets. When bucket with new tranny fluid gets nearly empty, switch the works off.
*Check fluid level. If necissary, insert hose into trans dipstick to extract some fluid. If necissary, add some fluid into the pan.
I don't know if that'll get nearly 100% of the fluid or not but, having talked to some mechanics, they say it'll work. However, being cautious and from a technical backround, I like to triplecheck a process before doing it.
90Brougham350
01-15-07, 10:30 AM
You are exactly correct in your thinking. This process is the best method of changing the fluid completely.
Hammondsix
01-23-07, 11:01 AM
i tried this only to find that one line pumps out the fluid and the other did nothing. The other line didnt suck!
tipoil
01-28-07, 07:58 PM
your right Hammondsix mine too didnt suck
what i do when i change trany fluin is
drop the pan and filter
put new filter in
put the pan on
disconect cooler hose that exit the rad(if ur not sure witch one, try one and see from what end it flows)
overfill the trany ( in my case i put close to 8 qts in last time i think...)untill it start comming out of the vent
have someone start the engine in park
add fluid after 4 or 5 qts come out
when the good stuff come out(bright red trany fluid) stop the engine
replug the cooler hose
start er up again to check the fluid lever
if close to ok
run to all the gear a few time and recheck
if too high unplug cooler again and flush it up some more
if to low and a few in
remember full line on the dipstick is when the trany fluid is realy warm to the touch
hope it helped a bit
Hammondsix
01-29-07, 02:02 PM
I'm planning to install one of those shiny aftermarket pans that has a drain-bolt and change with the engine oil every 7500 miles.
90Brougham350
01-29-07, 02:27 PM
Dear God! 7500 miles is too often. No need to change the fluid less than every 30 or 40,000 miles.
Old Fleetwood
01-29-07, 05:22 PM
Amen to the 30,000 mile change.
I'll take the work of Shane Cobb of Carolina Performance Transmissions, especially since I'm driving around with one of his Stage II 4L60E Units in my 95 FWB.
Sure, some say you can go a lifetime with no change, etc., but Shane says for best results go with GM's "Hard Service" recommendation of 30K miles change.
But 7,500 wouldn't hurt anything but the pocketbook!:rolleyes:
Hammondsix
01-29-07, 05:58 PM
I disagree, the standard 30k mile fluid change calls for ALL of the fluid to be drained. When you drop the pan you only get 5qts or 1/3 of the fluid out of there. Thus the need to do it more often than 30k miles. Now if one unhookes the coller lines and get the additional fluid out of there, thats another deal.
Old Fleetwood
01-29-07, 11:28 PM
Okay - I think I see where you're coming from. You're getting that 30k change, 5 quarts at a time every 7.5k miles.
Right?
Hammondsix
01-30-07, 01:33 PM
precisely;)
Gwokable
02-02-07, 09:02 AM
Every 20k is best IMO.
Old Fleetwood
02-03-07, 12:10 AM
Do you mean a FULL FLUSH AND FILTER CHANGE EVERY 20,000 MILES?
Hammondsix
02-03-07, 09:17 AM
Numerous people on the board have said that flushing is a bad thing and makes the trannies blow up in million peices. I have done it twice with my other cars and they never did catch on fire, blow up or turn into lava. Maybe this subject would be suitable for the www.impalassforum.com since those guys eat trannies for breakfest.
dustman
02-03-07, 01:57 PM
What i am about to post is not speculation or hearsay but FACT.
The 30K Pan drop and filter change is the GM recommended service.
This is what should be done to all 4l60e equipped cars. Nowhere does hydramatic recommend flushing on the 4l60e in these cars. INfact when i was forced to flush transmissions at a dealer that i worked at that Upsold aftermarket BG flushes i saw some transmissions die in short order after a flush.
You must remember that a transmission isnt a engine. Super slippery ISNT what we want. We WANT some friction floating in the fluid. All the CRAP is in the filter. So unless your drag racing your 4l60e EVERY wekeend do a 30K serice Pan down and filter change.
If you drag race often once a year regardless of mileage.
Stick With GM Dex 3 and also do NOT do flushes only pan downs. If your told otherwise your told wrong.
blackcadmatt
02-03-07, 07:50 PM
I had the tranny in my '89 Brougham professionally flushed at a garage using a MotorVac tranny machine that I sold them. No mess no fuss, AND the torque converter gets cleaned too. The car runs and shifts like new! It was free for me as a demo but most shops charge less-than $100 for this service.
It's well worth it!
Old Fleetwood
02-03-07, 09:41 PM
Ladies and Gentlemen. HEAR YE, HEAR YE !
The modest appellation "Dustman" is none other than Shane Cobb of
CAROLINA PERFORMANCE TRANSMISSIONS:welcome:
Okay, so I'm biased since I'm driving around with one of his units in my '95 Fleetwood, sometimes pulling an almost 1-ton PopUp RV and other times loving how the Cadillac:
>is smooth as oil over a bald head when taking off on black ice due to the high slip converter.
>gives me total confidence when towing that the 4L60E won't drop dead when we're in the middle of the Sonoran Desert next year.
>the whole package - as Shane said - makes the car act as if it's half a ton lighter if you want to play Grand Prix games at traffic lights. (just pick your enemy right and don't "f" around with Subaru WRX's)
Gwokable
02-06-07, 02:47 AM
Makes some sense. I was saying, filter and pan fluid change every 20k. Transmission fluid has a tendancy to oxidize as time goes on from my understanding, so regular flushes help to keep the fluid from getting especially rank. The only reason I bring it up is because I have a car that sat in a garage for 5 years and the trans recently blew, in this instance with a stored car you want to change 90% of the fluid.
The mechanic recommended I do a trans fluid flush and filter change after 1000 miles. Does that sound correct?
