View Full Version : pcm location on 94 sts?
onefastsunsetss
01-13-07, 05:32 PM
i've been searching endlessly, and can't find the pcm.
its not under the airbox like everyone says.
can anyone help?????????????
Ranger
01-13-07, 06:54 PM
I think the '94 is behind the glove box or in that vicinity. I forget when they moved them to under the air intake box.
Cad tech
01-13-07, 07:52 PM
Access to pcm, take off lower kick panel under glove box, remove the 10mm screws holding it in place unplug both connectors, remove.....In 1996 they moved them under airbox.....
clarkz71
01-14-07, 09:33 AM
Actually, it's one 7mm screw on the right side of the PCM, the left side has a locating pin. And it has 3 connectors. It makes it easier if you remove the glove box also (six T-15 torx screws). I just replaced the chip in my PCM so it's fresh in my mind.
93-95 Cadillac PCM:
http://i86.photobucket.com/albums/k120/clarkz71/PCMNorthstar123.jpg
onefastsunsetss
01-14-07, 01:51 PM
thanks....i'm doing headgaskets\timesert and hopefully i'll be able to feed those three harnesses up through the firewall. after everything that fought me, the only thing stopping me from lowering the cradle was this.
Cad tech
01-14-07, 08:59 PM
does not have decent bulkhead connector and the access hole is to small to get it through, unless you mangle plug and firewall adding a wind leak....Just pull the wiring off block and on your 94 it is pretty easy..
