View Full Version : 3.6L VVT Engine Powerband
b4z
03-12-04, 05:45 PM
Is it just me or does the 3.6L have proportionally more power in low end and midrange than the topend?
Mine pulls extremely well but when i get up into the upper rpm band there is not as much power there as i expect with a OHC motor.
Anybody else observed this phenomenon?
doncapecod
03-13-04, 02:55 AM
I haven't seen the torque curve on the V6, but if it's like others torque will level and fall off before redline, so I don't know where peak is????
hog4oc
03-13-04, 06:07 PM
The factory air intake system is very restrictive, if you add a cold air intake system that will open up the power bank above 3500rpm, you can feel the difference. I did on my V6 and love the power and throate respone.
Cheers:coolgleam
Srevi
03-14-04, 12:01 AM
Hog4c, I have noticed the top end drop off and had figured a Cold air intake would solve that in my research. I'm waiting for Volant to produce a model for the SRX similar to their CTS V6 solution. I contacted them and they said it would be available in April. The only concern I have is the some of the Cold Air Intakes I have seen on other installations were really!!! loud. I wouldn't mind a little more throat and I definitely want the high end boost but I do use the SRX for business and customers and am a little nervous. How much louder is it once you are at speed?
Anyone had any first hand experience with the Volant poducts on other vehicles?
b4z
03-14-04, 11:07 AM
I am a little surprised at how loud this motor is on the top end and it is not as smooth as i would like. It is no Honda DOHC.
But it has some serious go power.
hog4oc
03-14-04, 06:18 PM
Not loud at all, as matter of fact it is quiter than i thougt, i did my cold air intake myself by using my friend's subura WRX tube. See my previous posting for picture. It only cost me $90 including labor.
Cheers
miscreant
03-14-04, 06:23 PM
V6 is the white solid line, V8 is the dashed black line
http://www.ctsowners.com/images/srxpowerband.jpg
miscreant
03-14-04, 06:26 PM
Volant products are typically quite quiet, because they are not fully "open". Some argue that this restricts flow and that Volant intakes don't flow as well, but it's probably a minimal impact.
Osogato
03-14-04, 11:13 PM
Thanks, that is pretty cool.
Could you repost it in a way that shows us the scale for x and y axis? (e.g., bhp and rpm?)
b4z
03-15-04, 10:23 AM
That is very cool.
We don't know the rpms, but it looks like the V8 continues to climb while the V6 plateaus.
Maybe that is what I am feeling.
