: please post the headlight removal diagram
gort
01-12-07, 02:49 PM
Been a while since i've replaced a DRL. I did it last on an 02. Can someone post the diagram again to safely remove the headlight assembly on a 2004 lade?
larfx
01-12-07, 06:00 PM
You could just let the light stay out and save the trouble ;).
Sorry for not being a help to your question, but if you get the diagram, you could use it to turn the other one off, as well.
It would be great if we had less DRLs :).
DLE
01-12-07, 06:31 PM
1. Open hood
2. Take off the plastic cover by taking off all the snap clips by using a flathead screwdriver. (i'm guessing there's 7 of them)
3. On top of the headlight, there should be 2 "L" or "7" shape metal bar thingy. lol. Not sure how to call it. Anyways, take those two out.
The headlight should now pop right out. It'll be easier if you pop the side of the grill off too. Just dont take the whole grill off.
Anyways, you can always look in your manual as well.
gort
01-12-07, 06:33 PM
1. Open hood
Thanks. That's what I remembered (not needing any special tools) just wanted to double check. Better safe than sorry. Gonna get my dead bulb fixed tomorrow when there's daylight.:cool2:
DLE
01-12-07, 08:12 PM
You should buy these bulbs to put as your DRLs.
These are by far the best bulbs i've ever used for my DRLs. Looks just like HIDs from far away. :thumbsup:
http://cgi.ebay.com/ebaymotors/3157-24-LED-Lights-White-2-Bulbs-TurnSignal-BackUP-Tail_W0QQcmdZViewItemQQcategoryZ33713QQihZ005QQite mZ150079232667QQrdZ1
gort
01-12-07, 08:21 PM
Any modification required to use those or dot hey just pop in?
benamaster
01-12-07, 09:03 PM
For DRL's they just pop in. I used some tower looking LED ones. They are very nice and look alot better than stock and last longer too.
gort
09-20-07, 05:48 PM
Here to resurrect this thread. Those suggested DRL's were awesome, look just like HID. One finally burnt out and I need another set but the auction is too old to find. Anybody have an updated place to get more?? :D
DLE
09-20-07, 07:14 PM
Dont you ever resurrect a thread again! Just kiddin. :)
Go to ebay and type in 3157 white..
Find some here.
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=3157+white&category0=
jrs05caddyext
10-05-07, 06:53 PM
does anyone have a real picture diagram?
spirit man
05-11-13, 11:02 PM
1. Open hood
Anyways, you can always look in your manual as well.I followed these steps a few minutes ago. However, after unplugging the harness, there is a tube like wire. What is it and how can it safely be removed?
http://i179.photobucket.com/albums/w303/ctl46/Forums/th_null-1.jpg (http://s179.photobucket.com/user/ctl46/media/Forums/null-1.jpg.html)
http://i179.photobucket.com/albums/w303/ctl46/Forums/null.jpg (http://s179.photobucket.com/user/ctl46/media/Forums/null.jpg.html)
the cadillac man
05-12-13, 02:31 AM
[/URL]
[URL="http://s179.photobucket.com/user/ctl46/media/Forums/null.jpg.html"] (http://s179.photobucket.com/user/ctl46/media/Forums/null-1.jpg.html)
That wire is for the hid low beam bulb and can be removed at the ballast(just don't break nothing)just follow the wire to the ballast behind the grille
spirit man
05-13-13, 02:18 AM
The plug that is disconnected goes into the ballast. That's the only thing that has a connector into the ballast.The is not connector to the end of the tube going into the ballast. The ballast I have is OEM, but I left it there for now.
the cadillac man
05-13-13, 03:09 AM
There is two harnesses the larger one(which I see disconnected in the pic) and a smaller one which is for the hid low beam only and the connector for it is on the ballast located just behind the grille(remove it to gain access to the ballast)
The connector is like a headlight bulb harness and is easy to remove
I have had my headlight out before to clean them but I never disconnected the hid ballast as I had just enough slack to get the housings to where I could pour the water in the drl socket holder(I had the haze on the inside because of the drl bulbs) then worked it around then drained it
One word of advice don't mess with the hid bulb glass(the grease on your fingers will kill the bulb in no time) or have the headlights on with a hid bulb disconnected as damage to a ballast will happen
