View Full Version : Coolant Level
STS127
01-11-07, 05:08 PM
If the check coolant level message displays on the information center how low is the coolant, how much needs to be added. It occured while I was driving today and drove it around another time and did not pop up. The time it happend though the engine was very cold and the message came on right when I pulled out of the school parking lot. Would the cold weather have anything to do with it? Its in the mid 20's today so it is fairly cold out.
Ranger
01-11-07, 07:14 PM
I'm not exactly sure when it is tripped, but it is before it gets critical. You still have coolant in the tank. Just bring up to about 2" from the fill neck. Then keep an eye on it to figure out where it is going.
Flynn
01-13-07, 12:04 AM
My car has a slight coolant leak at the radiator. (bottom hose I think, haven't crawled under to pinpoint it yet) Anyway, the "check coolant level" shows up on the DIC about every two months or so. I have a 12 oz plastic bottle I fill halfway with DexCool, the other half with distilled water, and pour the whole thing in the surge tank. Not real fancy, but it works.
STS127
01-14-07, 10:54 AM
How much does a 96 STS take-15 quarts?
benshizzle
01-14-07, 06:22 PM
I get this message also. It says check coolant level when its cold outside (below 20F). I popped the hood and it WAS low but after driving for 2 minutes the message went away. I pulled over into a parking lot and checked again and the coolant was at the right level. I think coolant might contract and expand depending on the temperature. this happened in my 2000 DTS a couple of times after sitting outside in cold weather over night.
Ranger
01-14-07, 10:18 PM
If coolant concentration from cold temps is turning on the CHECK COOLANT LEVEL message, then the level is too low to start with.
STS127
01-15-07, 02:06 PM
Just bought some Dex-Cool and hope to change coolant this week. I'm figuring level is low and don't know when the last time it was changed(Have maintance records so I'll check them) so I think just changing it all together would be better than adding some.
Cad tech
01-15-07, 02:15 PM
12.5 quarts
STS127
01-15-07, 04:51 PM
^^ Yeah I think you're right. Transmission is 15 quarts right.
Cad tech
01-15-07, 04:54 PM
Transaxle
Drain and Refill, Requires Drain Plug Removal
10.4 liters
11.0 quarts
Overhaul
12.0 liters
12.6 quarts
Dry
14.2 liters
15.0 quarts
detroit99sts
01-18-07, 01:03 AM
My coolant level is low also. how often is it recommended to completely change (drain & fill) the cooling system? Ive had the same coolant for 2 years now. Should I drain & fill? Is it safe to flush the system?
Ranger
01-18-07, 12:18 PM
Your '99 has orange Dex-Cool so once every 5 years. 2 years for green coolant.
bigmike750
01-20-07, 11:11 PM
dont forget to add the tablets to the dex cool....and smash them up before you put them in
Ranger
01-20-07, 11:25 PM
No need to crush them in a Northstar. Just pop them in the radiator hose whole. DO NOT put them in the surge tank.
Mountie
01-23-07, 03:24 AM
When I replaced my Northstar, I upgraded my oil cooler to about twice the size ( same brand - same bolt install) .....Totally dry, I put in 10 quarts oil in the engine.
