smooththg6969
01-10-07, 07:00 PM
well a couple of you know about my cracked block and me rebuilding another block the rust in the bore etc.. well I finally started putting the block together day by day so heres a couple of pics of my progress
pistion ring thread
http://www.cadillacforums.com/forums/northstar-performance-technical-discussion/91248-reuse-pistion-rings.html
cracked block thread
http://www.cadillacforums.com/forums/northstar-performance-technical-discussion/90043-cracked-block.html
http://i125.photobucket.com/albums/p70/smooththg69/Image033.jpg
http://i125.photobucket.com/albums/p70/smooththg69/Image032.jpg
http://i125.photobucket.com/albums/p70/smooththg69/Image031.jpg
http://i125.photobucket.com/albums/p70/smooththg69/Image030.jpg
http://i125.photobucket.com/albums/p70/smooththg69/Image029.jpg
I inserted a pistion in the bore with the rust after I cleaned the bore and honed it with the berry hone it moves smoothley that is the only bore I honed. Im hopeing not to loose more than 10 psi even though the FSM says 140-170 psi is the acceptable range now my only fear is it not starting after I get it back together but i ill take my time getting it back together and hopfully it will run with out problems.
pistion ring thread
