: starter
01-07-07, 02:47 PM
i havent driven my fleet in 9 days, so i jump it off all the lights come on but it wont turn over, so should i just let it charge more or just change the starter, and how can i tell if the starter is bad anyway and how do i locate it to change it anyway,
01-07-07, 08:40 PM
what happens when u turn the key? does the lights dim? can you hear the starter clicking?
01-07-07, 08:47 PM
If you hear the starter clicking, your battery is too weak yet. To determine if the starter is bad you can take it to Auto Zone or other parts stores, and they can test the starter and the starter solenoid to see if either is the problem.
01-07-07, 09:09 PM
1:turn the key
If lights Dim and nothing happens;
OK then your starter has a short.
2:Turn the key.
If you hear the starter clicking and the light dont dim.
Starter solenoid
3 turn the key.
If you hear the starter clicking and the lights dim.
Check battery terminals for corrosion
check battery (at part store)
01-08-07, 08:18 AM
did u figure it out?
01-08-07, 01:53 PM
STarter is located on passenger side of engine, right where oil pan meets the block. It is under the exhaust manifold.
