View Full Version : Granatelli Mass Airflow Sensors
rodcole1
03-11-04, 01:52 PM
Has anyone tried the Granatelli mass airflow sensor on their Escalade ??
rodcole1
ChiMick
03-11-04, 02:17 PM
I don't have experience with their products, but the Granatelli Brothers seem to have a certain touch for American iron. I would not be surprised if they are well worth the cost.
MEJIA
03-15-04, 10:35 AM
I first bought the Granatelli Mass Airflow Sensor and did notice a slight difference in performance, when I really noticed a greater increase in performance was when I used this sensor and the Predator programmer.
hcvone
03-15-04, 01:40 PM
I personally dyno tested 4 GMS MAF's on my Z06, 2 of them lost power and the other 2 made no more power. Sport Truck magazine did a test on a Chevy truck and they reported a loss of 8 rwhp, the test was done in the magizine last summer.
elwesso
03-15-04, 03:52 PM
I dont see how changing the MAF would get you any more power.....
84caddy
03-17-04, 01:45 PM
I installed a K+N filter kit on my 00 escalade and it tended to bog a bit - and make more noise than power...later I installed the Gran. mass airflow sensor, and it improved the bog/hesitation
elwesso
03-17-04, 04:05 PM
Bet that the K/N caused the MAF to become dirtied..... Therefore reading incorrectly...
84caddy
03-19-04, 03:49 PM
either that or the factory MAS couldn't read the new airflow from the kit making it worse! The Gran MAS prob brought it back!!
artiesauto
08-10-04, 05:12 PM
:bonkers: tried one on my 04 ecalade/ feltgood/ but set off my
check enginelight/ no help from granatelli tried 3 times to reset
sent it home :rant2:
fast66
08-10-04, 05:43 PM
... Never used them before.
T_Dogg8
08-11-04, 07:14 AM
mass airflow sensors are one thing i don't mess with. the gains are minimal, but the chances of screwing something up are greater.
jamesmbond
08-22-04, 01:26 PM
I recommend you DON'T BUY the Granatelli Mass Airflow sensor at all. Had it installed in my 2002 Escalade and it throws Check Engine lights. I purchased a Diablo programmer that can also read the codes and also had my mechanic check and recheck the system.
Turns out that the Granatelli causes the engine to think things are running too lean and even the 5% adjustment to the fuel/air mix you can make with the Diablo isn't enough to stop the Check Engine lights.
Made two calls to Granatelli and the are NO HELP WHATSOEVER and played dumb with something like "this behaviour is unusual" which is crap as everyone seems to have the same problem.
Just installed the stock airflow sensor back in and everything is fine now (still have an aftermarket cold air intake but just using the stock MAF).
