View Full Version : 2006 SRX Fuel Door Won't Open
SRXES
01-07-07, 08:28 AM
Hi. I am new to the forums and also a new 2006 SRX owner. I have bought gas one time and pushing on the rear edge of the fuel door to get to the gas cap worked fine the first time. Now, I need to get gas again and the fuel door does not pop open when I push on the rear edge.
Has anyone else had this problem, and how can I get the fuel door open?
There is no remote control for the fuel door, just a manual push.
Also the weather here in Georgia has been unusally warm, so it is not a cold
weather factor.
Thanks for your assistance, SRXES.:banghead:
Oso
01-07-07, 08:32 AM
Try pushing on near the center. It should pop open unless it is stuck for some other reason. It has a spring-loaded latch like a lot of cabinets with glass doors.
SRXES
01-07-07, 08:46 AM
Oso,
Thanks, your explanation helped me understand the functionality better.
I pressed in the middle with the flat of fist, instead of my fingertips and I have now opened it twice. Feeling much better.
SRXES:yup:
c5 rv
01-07-07, 09:20 AM
If the little pop-out mechanism ever gets hung up, you can slip your fingernail behind the rear of the door and just pull it open. There is no latch holding it closed, just a spring. Just don't use anything that would scratch the paint like a bare key or screwdriver.
davedogcaddy
01-09-07, 03:37 PM
weather factor.
Where in GA are you? I'm in GA too, seems like I never see any other SRXs besides mine... :rolleyes:
