Radio was fine one minute, then no sound, and stations won't change.:cookoo: .. (locked inbetween a station ) :banghead: :banghead: :banghead: :banghead: Everything else works.....Whats going on with it? :mad2: :mad2: :banghead: :banghead: :banghead:
lol
its a bcm lock up
1st pull the codes for anythin weird
then
unplug the amp fuse and radio fuse turn on car then turn off then plug everything back in
HUH? BCM lock up eh? First time I've ever heard of that term :duck: :cool2: ... .. Well I have no code cuz I cleared them all yesterday after working all day on the suspension.
I'm making another post relating the suspension work I did. :helpless: :helpless: Anyhow, I'll double check for codes tmw and see if I can locate the Trunk power center without having to dimantle the entire trunk!!:banghead: :banghead: :bomb: !
Oh yes... Easy as pie to pull a couple fuses..... If I knew where to find that rear relay center.... I've been trying to find it in the FSM... no luck yet...I'm thinking I've get to pull some panels loose? But which ones?
everythings fixed?
thats good
yup
its known as BCM lock up never had it happen on lacs but all the time on Cateras thats how i know about it glad it worked for you too...
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
