: a/c compressor
01-04-07, 06:34 PM
has anyone had to change out an a/c compressor on a 95 sls mine went the other day so i went and bought the repair manual and all the evac. tool for the refrigerant but i was wondering if anyone could tell me how complicated the job is and if there's anything to keep in mind or pay attention to while doing it?
01-04-07, 07:21 PM
It's not that bad. First remove the engine belt, then you need to remove the r/f wheel, then the plastic panels to access the front of the compressor. There's 3 15mm bolts. Then you remove the plastic panel under the radiator and remove the oil filter housing/adapter to acccess the rear of the compressor where you'll find 2 10mm bolts and a 15mm bolt which mounts the manifold hose. The compressor comes out through the r/f wheelwell. You'll need the 2 o-rings for the oil filter adapter part # 3543719
01-05-07, 10:36 AM
thanks alot
