: Adjusting the Stock Amplifier?
01-04-07, 10:20 AM
Can the stock amplifier be adjusted? Can I increase or decrease the gain? I recently had an aftermarked headunit put in ( with help from ETC97 and others ) and I was wondering if the gain on the stock amp could be adjusted or if it has a bass boost? Never really took a look at it, and figured I'd ask.
01-04-07, 12:34 PM
yes and no
you can turn the volume of the amp up with the wheel controls provided you used the gmos-06, and the volume of the hu up via the vol knob on it...
01-04-07, 01:10 PM
Hmmmm, I've tried to turn the volume of the amp up and down using the wheel control with no effect. Not sure whats the problem.
01-04-07, 01:14 PM
06 should maintain wheel controls....
vol does vol control of amp
seek does fade control front to rear...
01-04-07, 03:18 PM
I'll make another attempt to test this, and get back to you later today, but I am sure I 've tried it before with no good results.
01-06-07, 03:19 AM
What exactly is the volume control of the amp?? Amps don't control volume!
