View Full Version : '06 halfshaft part #
rlj5
01-02-07, 03:00 PM
anyone have the current part #'s for the '06 halfshafts ?
The Tony Show
01-02-07, 05:10 PM
19148846 - Left hand side
19148847 - Right hand side
rlj5
01-02-07, 05:33 PM
Thanks, Will be getting my V back from EPP with the ProCharger & kooks Probably Friday. Since I already have the '06 diff I'm thinkin about putting the larger halfshfts in So I don't take a chance on breakin a halfshaft & tearing out the diff when it happens. One of the forum members, can't remember who, had that happen when the halfshaft went.
How much labor is involved upgrading the halfshafts ?
The Tony Show
01-02-07, 05:48 PM
Very little. You can move the rotor/hub assembly far enough out to remove the axle shafts by disconnecting the control arm from the assembly.
austin
01-02-07, 06:51 PM
www.gmpartsdirect.com sells them for $312.00 & $325.00. I think you need a special tool that fits into the axle seal at the differential to release the halfshaft.
05CTS
01-02-07, 08:14 PM
You should cryogenicaaly treat them too. That should help strength wise.
