: Firewall Passthrough
stevebuick23
12-28-06, 04:32 PM
Ok, I need to run a power cable for my amp through the firewall somewhere. Is there one on the passanger side or the drivers side?
winnipegSTS
12-28-06, 08:22 PM
Off topic but ... what automotive shop do you work at ? Saw your tint and might need to come by and get some work done on my STS from ya. Im assuming your in Winnipeg that is
weister42
12-28-06, 09:27 PM
Depends on what size your wire is. Usually the easiest thing is to bore a hole in your firewall then apply liquid rubber over the sharp edges, run your cable through then redo it again. The car's sheet metal is pretty thick though.
stevebuick23
12-28-06, 10:05 PM
I am at CarVista. If you want tinting done, I'll do it at my house. My number is 292-7308, and my name is Steve.
the727kid
12-29-06, 02:46 AM
I already had a hole on my ETC on the drivers side. It was big enough to run 0 gauge through.
dp102288
12-29-06, 08:54 AM
Oh I thought it was Buick23! :D :p
Was that factory or did someone else make that hole?
the727kid
12-29-06, 10:02 AM
As far as I know factory....there was no signs of previous aftermarket.
dp102288
12-29-06, 08:33 PM
^^ Okay, just wanted for reference. :)
stevebuick23
12-30-06, 11:16 AM
I located a pass through with a little flappy window on the drivers side. Looks like I'll be using that one. :)
timothyr
12-30-06, 11:48 AM
ballpark, where was it on the drivers side?
stevebuick23
12-30-06, 04:18 PM
Near where the parking brake meets the body. Up just a wee bit, close to where the dash plastic cover begins. Look in the engine bay, and its a rubber plug, right to the drivers side, bottom of the master cylender.:thumbsup:
timothyr
12-30-06, 07:54 PM
so cool....will check it out
