View Full Version : Changing the FM Tuner frequency from US standard to European or both.
medlines
12-25-06, 04:36 PM
On an 07 Escalade with navigation, Is there a way to change the FM radio frequency shift from odd to even , like instead of jumping from 105.3 to 105.5 ( US Frequency) to this 105.2 to 105.4 ( european frequency).
slk230mb
12-25-06, 06:08 PM
I think only the export versions of the Escalade can do this.
nyssa7
12-26-06, 03:10 AM
Does this mean when I bring an Escalade over to the UK the radio is going to be useless?
Super
12-26-06, 12:14 PM
the radio will work fine just as it is
nyssa7
12-26-06, 02:10 PM
I'll rephrase the question - had never thought about it before, but all the FM stations over here I listen to are "even" numbers - 95.8, 96.2, 107.4 etc
Do I understand the Escalade radio only tunes "odd" numbers or have I completely misunderstood?
medlines
12-26-06, 03:10 PM
The Radio in the Escalade only receives odd FM frequency, 102.3 - 100.7 - 99.1 .
But you can change the Speedometer, odometer from miles to Kilometers and the tempreture from Farenhigt to Celciues, using the computer on board, but it it is odd to me why you cannot change the FM frequency at the same time when you shift from English to Metric.
yourgmsolutions
12-27-06, 08:39 PM
if you were in CA, i could solve this problem for you. I had my of my friend with the same complaint and I recalibrated his tuner for european standarts. coolest part was, XM/AM/FM still worked fined but the numbers on AM/FM worked a little differently
yedaiwi
03-13-15, 05:47 AM
I am in the UAE and have the same problem. Is there a way that I can recalibrate the tuner?
N9LO
03-13-15, 10:20 AM
I found on the internet you may need a Tech2 or equivalent to change the zone of the vehicle but it was for an 05.
the cadillac man
03-13-15, 10:28 AM
N9LO is correct you need a tech-2 to change that
