: Can someone tell me what GM PN's 1052080 & 12345382 are?
Lawrence
03-08-04, 06:46 PM
These are listed in the manual as thread sealer/lockers. I assume they are Loctite products. Can someone tell me what the Loctite number/type is?
Thanks Much,
Lawrence
BeelzeBob
03-08-04, 11:45 PM
Thanks Much,
Lawrence
Where are they referenced for use and I can tell you what to use.....
Lawrence
03-09-04, 11:03 AM
12345382 > Torque Converter to Flywheel - Intermed Pipe to Cyl Hd - Suction Pipe -
1052080 > Flywheel - Water Pmp Hsg to Head - Cam seal Retnr to Cover
Thanks bbobynski!
ThomasO
03-09-04, 11:38 AM
See if this helps
1052080- http://www.permatex.ru/pc/exch87.htm
12345382- http://www.permatexkorea.co.kr/doc/help/table/chart1.html
............ThomasO
Lawrence
03-09-04, 12:37 PM
Thanks ThomasO.......
Your site says 1052080 is "Permatex High Temp Thread Sealeant"
and 12345382 is "Permatex Low Strength Threadlocker" Purple
I also found this on the Loctite site.......
It says the 1052080 is Loctite PST 592 Thread Sealant
and 12345382 is Loctite 242 Medium Strength Blue Threadlocker
Hmmmm......
Things are all screwed up since Permatex got involved with loctite.
