View Full Version : its alive, its alive, its alive!!!!
dvandentop
12-19-06, 09:07 PM
Well got the V running today!!!! :cool2: :cool2: :cool2:
It turned out that i had the crank sensor and the oil level sensor switched around, so i swapped those today, went to turn on the key, and the guages didnt light up and when i switched the key nothing! I was like WTF it cranked yesterday, so i called JAMES, the man @ lindsay, him and ewillard3 helped me out over the phone, they suggested to check the grounds. So we got off the phone i did that and still nothing.
So i swapped around some of the 4 relay switches in the main box and finally got some dash lights. Cranked it up and my god it started!!!!
Might have some bad gas in the tank though not sure, but did get it off the jack stands and it did move under its own power!!!!! I was so pumped I was like a kid on christmas!
here is the vid
nothing special but here it is running http://www.upwithpunk.com/portal/e107_images/emoticons/grin.gif http://www.upwithpunk.com/portal/e107_images/emoticons/woot.gif
http://sio.midco.net/dvandentop5/MOV02766.MPG (http://sio.midco.net/dvandentop5/MOV02766.MPG)
and here she is back on the ground after being in the air since like August!
http://sio.midco.net/dvandentop/DSC027681.JPG
BLACK_CTSV
12-19-06, 09:16 PM
Holy crap!! Nice work, Derek!! Can't wait until you can drive that thing! :cheers:
12-19-06, 09:21 PM
:nanaparty:
That's great... Good to hear it running...
DILLIGAF
12-19-06, 09:23 PM
here is the vid
Congrats dude!!!!:burn:
Drift-caddy
12-19-06, 09:27 PM
Congrats. If you need anymore help you got my number so give me a call.
thanks
Damian
BTW you have a PM
heavymetals
12-19-06, 09:29 PM
Nice, congrats.
And somebody gives me crap about my having a dirty rear view mirror....:want:
dvandentop
12-19-06, 09:29 PM
:nanaparty:
thanks again for the help James and ewill3rd!
also deffinately going to need corsa and headers this thing is wayyyy to quiet :D
Chef
12-19-06, 10:10 PM
Somebody needs to send ya a box of cigars!
well done!
12-19-06, 10:22 PM
Always glad to help out... Don't hesitate to call if you need anything else...
rand49er
12-20-06, 05:58 AM
:worship: :worship: :worship: Outstanding!!! Chef's right ... get out the cigars!
BTW, I liked the little touch of showing the exhaust coming out the back. :D
svassh
12-20-06, 10:33 AM
Congrats - Its always the little things isn't it?
LUVMY04V
12-20-06, 12:57 PM
What did u pay for that??? If u dont mind me asking....I was thinking about selling mine and trying to do the same thing with a rebuilt title
HushH
12-20-06, 02:36 PM
:thumbsup: Great to hear.
GT04CTS-V
12-20-06, 07:40 PM
Nice work!
GT
ewill3rd
12-20-06, 08:15 PM
I am glad to hear that we were able to help you even a little bit.
I have some funny stories to tell about people switching connectors.
We had one guy, when I worked in Missouri, that almost hydro locked an engine because he switched the connections between the transmission and the fuel rail on an Aurora! The PCM was commanding several injectors open all the time because it thought it was trying to turn on a transmission solenoid and it was dumping gas into one or two of the cylinders, we all laughed ourselves silly when we found out what happened.
They usually try to use different connectors for most things but once in a while you can swap one.
It's really cool that you got it running.
dvandentop
12-20-06, 09:51 PM
damn i am glad mine wasnt that bad haha! :crybaby:
Yeah after tearing the motor out in august and finally get the other motor up and running in december is quite the time frame to recall, especially since the both had 3 pins in each connector :ill:
btw do you know any way to test out relays to tell which ones i need to get new ones of and which ones are good?
:stirpot:
ewill3rd
12-21-06, 06:16 AM
They don't go bad very often but they could have been damaged by water intrusion. You said this is a flood car right?
You might just have to build a little rig to test it.
You any good with electricity?
Got some spare parts laying around?
We can build you a relay checker but it might be a pain to use.
Maybe you could find a circuit in the car that you could swap relays into, like a fog lamp relay, and you could test all the relays that way.
That may not work as well since removing relays will affect other circuits.
