: Navigation Problem!! Help!!!!
EscaladeEXT20
12-15-06, 04:23 PM
I just bought a navigation off of ebay, I installed it and as soon as i turned it on it says " THEFT LOCK ACTIVATED". Why does it say that? And how can i remove that?
Thanks!!!!
dkozloski
12-15-06, 04:36 PM
Thanks!!!!
It says that because it's smart enough to know that it's not in the vehicle it belongs in. Take your rig to any GM dealer along with proof that the NAV is not hot and in a few minutes they can unlock it for you.
TexasAg98
12-16-06, 01:02 AM
Yeah, what he said. You'll need the dealer to program your VIN to it.
How was the install? I'm looking to install the stock nav system as well.
EscaladeEXT20
12-16-06, 03:12 AM
Alright, Thanks!!
EscaladeEXT20
12-16-06, 03:13 AM
Install was real easy. I did it in like 20 minutes.
djmodifyd
12-16-06, 06:23 PM
did you mount the gps antenna where it's supposed to go?
or did you just shove it in the dash?
EscaladeEXT20
12-17-06, 04:26 PM
Thats the question i have now. Where should i mount the antenna? When i installed the Navigation i didnt have the antenna. I got the antenna today now i need to find out where to put it. Cause i dont want to just throw it in the dash.
flyingdutchman
12-17-06, 11:12 PM
Try this link http://www.cadillacforums.com/forums/cadillac-escalade-ext-esv-forum/21681-need-part-number-2005-escalade-touch-7.html
Post 62
To TEMPORARILY bypass theftlock do the following
1) Turn key to ACC position ( not run)
2) Wait for "theftlock" screen to appear
3) Pull radio fuse
4) Put radio fuse back in
5) Radio will work as normal until key is turned off or vehicle is started
Also:Reset Instructions
Document ID# 1275527
Radio Setup (With RPO UM8)
Radio Theftlock Clear Procedure
Complete the following procedure, using a scan tool, in order to properly set up communication:
1. At the Main Menu screen, select: Diagnostics.
2. At the Vehicle Identification screen, select the following options:
* Model Year
* LD Trk, MPV, Incomplete
3. At the System Selection Menu screen, select: Body
4. At the Vehicle Identification screen, select the following:
* Appropriate model
* Appropriate Air Conditioning
* Navigation Radio
5. At the Body Screen, select: Navigation Radio.
6. At the Radio screen, select: Special Functions.
7. At the Special Functions screen, select: VIN Relearn.
8. At the VIN Relearn screen, the scan tool will display "Do you want to clear radio theft information?"
9. To begin clearing, press the soft touch key on the top right of the scan tool. The scan tool will display "Clearing Radio Theft in Progress."
10. Press EXIT on the scan tool and cycle the ignition.
Important: The radio theft will learn the VIN. Without learning the VIN, the radio will display a locked message (LOC or LOCKED).
