: LS2 Vehicle?
nofinga911
12-14-06, 08:21 PM
In reference to the instruction booklet for my predator programmer...what is an LS2 Vehicle??
TheCaddyKidd
12-14-06, 08:33 PM
what model number is the programmer?? where did you purchase it from??
nofinga911
12-14-06, 09:11 PM
u7194 : predator : diablo motorsports
nofinga911
12-14-06, 09:15 PM
I couldn't just sit here and watch my programmer be worthless so I went outside to remove the fuses and give it another shot with the fuses removed...The problem is I cannot locate the following fuses, neither under the driver dash, under the hood, or in the manual... RADIO , RADIO AMP , INFO , SEO 1 , SEO IGN , RDO 1 , RAP 2 , TBC ACCY ....can anyone help?
slk230mb
12-15-06, 02:11 AM
If it's referring to the GM LS2 (which it most likely is) then that's the engine. Your truck doesn't have an LS2.
hcvone
12-15-06, 06:59 AM
As Steve said the LS2 is a GM engine that is in the standard Corvette and GTO, the trucks do not use the LS2
Mobius
12-15-06, 10:07 AM
Although, I have found out that the standard Escalade 6.0L engine is the LQ9. Which from what I have read is and iron block LS2 tuned down just a bit.
slk230mb
12-15-06, 10:09 AM
It's essentially a LS1 bored out to 6.0 with an iron block and vortec heads (which I've read flow as well as LS6 heads).
nofinga911
12-15-06, 02:09 PM
okk that clears up one issue....thanks a lot...appreciated! :thumbsup:
