drewsdeville
12-12-06, 07:56 AM
Hey guys, what's up.
I have a 1995 Deville that I got 3 years ago when I was 18. It was VERY cheap because of it's mechanical condition (but looked like brand new). Now in great shape, just passed 150,000 miles.
Recently, I have aquired a cold idle problem. The cars idle is unstable. It doesn't miss, it's just unstable and fluctuates +/- 100 rpm from about 550 to 700 rpm. It does this a lot cold and perhaps when it's warm as well, but just not as noticeable when warm.
When I got the car, it hardly ran. So, I tore it down. My first big car project. I replced the following:
All top-end gaskets (Intake Manifold, Valve Covers, Throttle Body, Egr...and such), but no headgaskets
Valve seals
Cap, rotor, wires, plugs.
All 8 fuel injectors (I found that 2 of these, and a loose dist. rotor were the reason it hardly ran when I got it)
Fuel, air, and transmission filters
PCV valve
Belt
and I think that's about it.
Trying to track down this problem, I found faulty and replaced the fuel pressure regulator.
Other things recently replaced:
ignition control module (dist. signal interrupt code...this fixed it)
both oxygen sensors
egr valve and controller (perhaps not needed)
all rubber vacuum connectors
complete exhaust system
All parts on this car are genuine AC Delco, including the plug wires. The only exception is the Walker exhaust system and Bosch plugs and O2 sensors. I have a hook-up that gets me 50% off of list price on all GM parts :)
I also cleaned the air temp sensor on the intake manifold
Going into the diagnostics, I checked the tps reading. It was 0.5 when warm and did not fluctuate.
Yes, the throttle body and egr tubes are clean. They are still very clean from the big job 3 years ago
I am at a loss as to what could be causing this, but it's annoying. One thing I have noticed is a howling noise with the engine running coming from near the p/s pump, which I also replaced last year(the reason I replaced vacuum connectors). The strange thing is, this noise goes away when the a/c compressor kicks in....
Any ideas??? I've been very good to this car because of the price I got it for. As you can see, I wanted a good start when I got it, and i did get a good start. I want to keep it nice... I'm very proud of it. There is a picture of the engine bay attatched form after I finished the big teardown :) Not the slightest hint of oil on that motor. Just nice silver aluminum block :) had about 120,000 on it at this time.
Valve seals
PCV valve
Belt
both oxygen sensors
