nctrader
12-05-06, 06:55 AM
I am having an problem that I can't find. It is on a 1998 Eldo. It does not happen all the time, but seems to be more frequent they symptoms are:
After sitting, it will not respond to the key transmitter
Doors will only open with key
No interior light when door is opened
Fuel door will not open
Trunk will not open
Trip, fuel used history is lost
Door locks will not operate even with the door switch
It WILL always start, but the alarm sounds untill I lock and unlock it with the key transmitter. The last time it failed I verified there was 12 VDC on the body control module. Also, when I try to open a door, or anything with the remote transmitter I do hear a relay pulling in, so I know it is getting the signal. The last time it did it I pressed the transmitter unlock button, and the driver door opened, I immediately pressed the open again to open the passanger door and it quit responding. I usually get the following DTC codes:
IPC
B1552
PZM
B1552
B2471
B2473
B2477
This is getting to be a pain. If anybody can help it will be greatly appreciated as I don't want to take it to the dealer. Thanks
Trunk will not open
IPC
B1552
PZM
B1552
B2471
B2473
B2477
