: check engine light
frontierman
03-05-04, 08:00 AM
My check engine light keeps coming on...1994 sedan deville
BeelzeBob
03-05-04, 01:28 PM
OK....there is a trouble code in the onbaord diagnostics that is turning on the light.
Simultaneously press and hold the OFF and WARMER buttons on the climate control panel with the key on until the onboard diagnostics activates. Read off the codes and see what they are. Post back for more info.
Impossible to say why the light is on without knowing what codes are stored.
frontierman
02-21-05, 02:04 PM
Here are the codes:
code po 13 history
code po 44 history
no ipc codes
noacp
no sir
notcs
so21 history
so 60 history
pcm?
That is all I got..Can you help?
Mike
frontierman
02-21-05, 06:23 PM
Here are the codes:
code po 13 history
code po 44 history
no ipc codes
noacp
no sir
notcs
so21 history
so 60 history
pcm?
Mike
mcowden
02-21-05, 07:42 PM
You posted the same thing three separate times. Go read your other post for answers.
frontierman
02-21-05, 07:49 PM
Yeah, I realized that..I have read the posts..Do you have anything to ad as far as a solution to the problem.
mcowden
02-21-05, 08:50 PM
Well evidently you didn't read much because I posted suggestions in your duplicate posting. Hope you get it fixed.
