100
11-24-06, 12:18 AM
Recently, the car (95 SDV with a 4.9) started to behave wrongly.
First thing I noticed was a slight, occational hesitation while accelerating. Then it progressively worsened over a few days, so when the car just gets into 4th + VCC-lock-up at about 44 mph with light throttle, the car shakes a bit. Feels like the enigne is missing a bit.
I checked fuel pressure and everything seems to be fine. I have fairly new ignition parts, so I started to check spark plugs. One looks a bit fouled, but others (I was able to check only 4 so far) look fine. After I changed those 4 plugs, the car runs much better, but I still feel that it is not running right, but the difference is not significant.
So, these are the back ground information... When I checked the engine, I just noticed that the EGR solenoid is making constant buzz sound, while the key ON, but the engine not running. Is it normal? Is it somehow related (I believe it could) to the problems I described above?
