View Full Version : The joys of DIY system install
vietfob714
11-23-06, 01:48 PM
All my systems i've done myself... its not super professional but I have the satisfaction of doing everything myself... heres just a sneek peek at what i'm up to. Hopefully i'll be done b4 2007.
By the way those are MB Quart Premium 15s... 4 goin in... I hope its loud enough
I know people are going to ask... that box is about 6 cu ft. 49x22x24
yourgmsolutions
11-23-06, 02:03 PM
based on dimensions You provided, this box is almost 15 cu ft.
here is the formula that may help You
A x B x C divided by 1728
vietfob714
11-23-06, 03:22 PM
Thank you for pointing that out... i think i screwed up. each sub needs 1.5 cu ft. i did 18"x18"x18" x 4. I should have done 12"x12"x12"x6. I dont understand why they arent the same #
vietfob714
11-23-06, 04:22 PM
so yeah i screwed up... i'm just gonna lose 2 ft off my bed and just fillin 9 cu ft of cotton. Thanks for pointing it out for me GMgeek.
yourgmsolutions
11-23-06, 09:42 PM
no problems, I'm glad I could help. good luck with your project
fast66
11-24-06, 08:17 AM
Looks good,
those are gonna be loud for sure, and man those will hurt.
Good luck and bump safely.
liftdlegend
11-25-06, 07:11 PM
You shouldn't fill it with cotton it's gonna trick the subs into thinking their in a bigger box. Fill it with expanding foam and then take a container or something that you know the volume of and use packing peanuts to determine how many cubic feet you have then if you need to add more foam or carve some foam away. It's definitely gonna pound:thepan: . What amp are you using?
vietfob714
11-26-06, 12:29 AM
MB Quart RAA1000 ... its pretty much a higher end rockford power 1000. 2 of those. I'm rebuilding it so it'll be about 10 cu ft and i'll fill it in with foam . I didnt know cotton makes it think that its a bigger box. How does that work?
RichieRich
11-26-06, 10:05 AM
I'd like to know how the cotton makes the speakers think that the box is bigger too... I'm doing my system on my EXT & that would be a big help.
yourgmsolutions
11-26-06, 01:19 PM
1 lb of poly cotton will increase .25 cu.ft volume of the box
djmodifyd
11-26-06, 02:41 PM
wow...looks like some nice stuff man
gluck with the install!
fast66
11-26-06, 04:48 PM
yeah i agree that cotton makes the subs think its a bigger box,
used it when I had 2 10"s under my rear seats.
vietfob714
11-26-06, 07:04 PM
can you guys explain why it does that? Just to know...
fast66
11-26-06, 07:56 PM
Googled:
http://answers.yahoo.com/question/index?qid=20061030101347AAB8hM1
http://www.lalena.com/Audio/FAQ/Build/
read the part on polyfill on the last link
zx6racer
12-03-06, 10:16 AM
The cotton holds in extra heat. I would not use alot of it.
