View Full Version : Where to plug Electric brake trailer controller?
Sta11ion
11-21-06, 12:16 AM
I want to buy a trailer with electric brakes and not surge, is there a plug in a 2002 ext to plug a brake controller for the harness I was told that its should be there by the seller of the trailer I havent found it though. Does anyone know if there is a harness around the glove box ?
gigarnage
11-21-06, 12:04 PM
Most trucks do not come standard with an electric brakes controller. This is probably something you need to have added by the dealership. I know that even with a towing package on my buddy's car he still had to have them set it up to haul a big trailer with electric brakes.
Supercrew632
11-22-06, 01:10 AM
Yes it is there, you should have a harness pigtail that came with the truck. You remove a cover by the left front kickpanel under the dash--the upper left socket is for this connector, then you just butt connect it to whatever brake controller you buy. If you do not have a harness, I can get one for you. Let me know how it turns out..........Supercrew632
Mobius
11-22-06, 02:05 PM
I'll second that, weel at least the existence of the pigtail and socket to plug into. When I bought mine, it didn't have the pitail (used). I told the dealer I wanted that pigtail and he found one in another truck and gave it to me. It plugs in exactly as noted above. The one I got had a placard attached that actually showed a picture of where to plug it in. I used a standard 7 pin plug and a standard brake. No problems towing also.
Sta11ion
02-07-07, 03:26 PM
I finally got around with this and I believe i found a connector under the dash thats on the other side of the fuse box it has a plastic cap that I gues your expose to take it off but there is over 7 wires going there. I wanted to know if this is it also what wire does what I need negative, power, brake lights, and wire that goes to the back. Any help since im buying my trailer on saturday that has electric brakes in detriot
