mike pruss
03-03-04, 02:12 PM
I have taken possesion of a new Cadillac SRX.. It's in Canada, so the XM was not available. XM does work up here, so I want to install an aftermarket XM unit, anybody done this ? any helpfull hints.
Thanks, Mike.....
p.s. would it be possible to replace the original head unit with an XM compatible one ?
doncapecod
03-03-04, 04:20 PM
Mike, pls let me know if you get any PMs on this. I couldn't order the satellite radio on mine because of the sunroof conflict, so I'm looking for a good aftermarket one.
I've heard that XM Commander is one of the better ones....just don't know yet if it is compatible with the SRX stereo system or just has to be hooked up to FM.
doncapecod
03-12-04, 12:16 AM
Mike, have you learned anything more on a satellite radio installation?
mike pruss
03-24-04, 03:06 PM
Don, here's what I learned. The factory stereo has a 2-pin type of antenna connection. So I purchased the FM emitting/power supply device ($30.00 at BestBuy) that is compatible with the XM Roady. Plugged it into the rear cargo area 12 volt lighter socket, tuned it to the 107.7 setting and voila' , XM through the radio. It seems to work pretty good. Mostly listen to talk radio (NASCAR, CNBC) and the audio sounds good. No 'hard' wiring required, and the antenna comes through the lift gate area. There is a lot of plastic in the roof area, so the antenna placement is somewhat limited.....
Mike
compfan03
03-25-04, 07:57 PM
Mike - can you please elaborate on your setup. There's a comment in another thread about the FM transmitter not working well with the Cadillac FM radio. Can you detail exactly how you set this up. FM transmitter gets plugged into 12 volt for power and into XM radio audio out? Is that how it works? Are you getting good radio reception?
mike pruss
03-26-04, 11:38 AM
Here is exactly what I did. Stuck the antenna near the back of roof, ran the wire through the weather stripping (put a small slit in the WS and then some black silicone to prevent any leaks. Tucked the wire under the WS and under the plastic. Plugged the power/FM emitter plug into the socket under the DVD player and ran the 3 wires down the side of the console and tucked them under the plastic. Mounted the roady on the console to the right of the shifter. Tuned radio to 107.7 and seems to work without any problems. The only wires that are visable are the three that come out of the radio, and these are exposed for about 4". So, in a nutshell, antenna wire comes from the rear cargo area, and the power wire and the signal wire go to the lighter socket under the DVD player. As for sound quality, I would say that it is better than using the cassette adapter and not as clear as a FM radio station. Unless you are a real audiophile, it's pretty decent. The best part is, no holes to drill, and I can remove the whole system in 3 minutes. Hope this helps.
Mike.....
mike pruss
03-26-04, 11:41 AM
one other note, there is not a lot of FM stations around here, so getting interference from other stations is not really a problem. The FM emitter/power supply device allows you to choose from, I think, 8 different frequencies.
Mike......
