: P0741 and state inspection
Dadillac
11-20-06, 10:38 AM
If your state/county has emissions inspection that relies on the OBDII and dyno method read this. My car has a faulty TCC and it throws the P0741 code. You will fail inspection if your car has any PCM codes. The way to combat this without having your car repaired (very expensive) is as follows. First, through the DIC, clear the codes. Do not go to inspection at this time as your emissions system will not be able to be read by the inspectors computer and you will fail. Drive the car for a week or two only in third gear. The P0741 only sets if yoiu are in overdrive and get above 41 mph. After your week or so of driving your systems will be "ready". Go back to inspection, and you should be golden. I checked for the code after every drive and it never appeared.
Don
99Classillac
11-22-06, 08:56 AM
good to know!
dp102288
11-22-06, 10:32 PM
Good idea to post this. :)
limoguy
10-24-07, 12:02 PM
YES!! I have the same code. Follow above instruction to pass!!:want:
Patrick7997
10-25-07, 12:57 PM
Nice... thanks for posting...
Talamant3z
03-20-09, 03:51 PM
what if u have a bad oygen sensor
cady97dev
03-31-09, 02:11 PM
Awesome tidbit!! Thanks for the info..
ThumperPup
04-05-09, 10:15 AM
Don
i have this code and also the 074 code comming up but i know my problem is the presure Relife vavle but just curous what is the TCC ?
ThumperPup
04-05-09, 10:16 AM
just wondering what is the TCC ?
Ranger
04-12-09, 11:05 PM
Torque Converter Clutch
daveyg
05-01-09, 09:58 PM
Awesome post bud! I have to go through my inspection soon and I wasnt sure what to do? Is it worth fixing the tcc and will it do any damage if I dont? I know the tranny has to come out to do it, so I mind as well put the head bolt kit in it when thetime comes. Let me know what you guys think about how long I can go with a bad tcc? thanks
jcresciSTS
09-01-09, 11:59 AM
I still don't know how my car passed, the SES light did not on until a few days after taking this test but yet after reviewing the previous owners service records it had been there for almost a year already. Very strange.
DevilleDeeman
09-11-09, 11:54 AM
It won't damage anything in your Tranny, you will suffer a couple of Mpg on the highway. Need access to the passenger side of the transmission for the TCC switch, its an expensive job.
Clem8fan
09-18-09, 04:47 PM
Does this trick work for any other emission related codes? IE PC0420? Worth a shot!
2001_Seville_SLS
07-08-10, 11:25 PM
Good post dadillac. There is more than one way to skin a cat.
For those that are inclined to fix the problem, here is a method of replacing the solenoid without removing the transaxle.
http://www.cadillacforums.com/forums/cadillac-tech-tips/203046-malfunction-indicator-light-p0741-p1860.html
bschelle
09-06-10, 04:08 PM
My 1999 Deville with 195,000 Mi. now thorws the code in third gear also. Any suggestions?
2001_Seville_SLS
09-13-10, 10:33 PM
Test the TCC Solenoid to see if it has failed electrically. Replace it using this inexpensive procedure if it has.
Dadillac
10-26-10, 08:57 PM
I would like to amend my initial post. My car started throwing code P0741 about 4 years and 40,000 miles ago. It would only set if I was in OD and went over 41 mph. The code is now setting if I drive in 3rd. I am getting ready to go through inspection and was going thru my ritual.
So at some point if you do not get your trans repaired the code will begin setting in 3rd which will make my initial post invalid. Sorry for that folks I didn't know
Don
Kevin Jaskulski
12-05-10, 01:53 PM
will this work on a 2003 DeVille?
Don
