: Front heated seats not working
11-20-06, 08:29 AM
Is there a quick fix for this?
bK caddy
11-20-06, 09:33 AM
check the fues
it happend to me befor and i found out that the fues was burnt out exacpt mine keep on burning, i think i have shorteg somewhere
11-20-06, 03:50 PM
Another thing to verify... make sure the wiring under the seat is intact...
When my driver's side went out... I was checking other aspects (as the fuses were good) and noticed that one of the wires connecting the heating element for the seat had been cut by the drive gear to adjust the seat... seems that there was no tie wrap to prevent the wiring from being loose, and I guess I might have pushed the wire at some point, in the path of the drive gear.
Was an easy fix, mended the connection.
11-20-06, 04:19 PM
Where would the fuse be located? The light works on the center console...just no heat.
bK caddy
11-20-06, 07:59 PM
hmm thats weird then well the fues is located under the steering wheel there would be all the fuese check your manual
