todd2fst4u
11-15-06, 05:52 PM
does anybody know how to replace the bulb that lights up the knob that opens the sunroof? any help is appreciated. thanks
| View Full Version : light on sunroof dial todd2fst4u 11-15-06, 05:52 PM does anybody know how to replace the bulb that lights up the knob that opens the sunroof? any help is appreciated. thanks APatterson 11-15-06, 06:27 PM you know.. i was thinking, this whole time my knob doesn't light up.. i didn't even know it was suppost to? so its suppost to light up? todd2fst4u 11-15-06, 06:38 PM yes it is supposed to. i got the bulb out. im not sure if any auto parts stores will have it though. todd2fst4u 11-15-06, 06:48 PM here is a picture of the bulb http://todd.bluesubmarine.org/Cadillac/DSCN8279.JPG 2000ForrestGrnCatty 11-16-06, 12:11 AM How do you get to the bulb? Mine is burnt out too. Thx. 2000ForrestGrnCatty 11-16-06, 04:58 PM Replies? Please? todd2fst4u 11-16-06, 05:58 PM alright i got mine fixed. i went to kragen to find a replacement bulb. they didnt have anything like it. so i went across the street to radioshack and found something similar. part # 272-1092 is what you want. http://todd.bluesubmarine.org/Cadillac/DSCN8287.JPG first step to accessing the bulb is rmoving the knob and cover to manual closing of the sunroof. http://todd.bluesubmarine.org/Cadillac/DSCN8280.JPG next pull on the plastic to seperate it from the trim on ceiling. http://todd.bluesubmarine.org/Cadillac/DSCN8281.JPG http://todd.bluesubmarine.org/Cadillac/DSCN8282.JPG next seperate the circular opening diagram from the rest of the plastic. http://todd.bluesubmarine.org/Cadillac/DSCN8283.JPG then seperate the circular diagram from the metal peice and remove it. http://todd.bluesubmarine.org/Cadillac/DSCN8284.JPG this is what you are left with. the hole on the right is where the bulb goes. http://todd.bluesubmarine.org/Cadillac/DSCN8285.JPG cut the length of the new bulb to match the old bulb and insert it into the hole. http://todd.bluesubmarine.org/Cadillac/DSCN8286.JPG thats all there is to it. now just reassemble. its pretty easy to do. you have to pull pretty hard on the plastic pieces sometimes to the point of where it sounds like things are breaking, but nothing does. any questions feel free to ask. inconnu 11-16-06, 06:08 PM Great pics thanks a lot,i will look into mine too,mine goes on and off. 2000ForrestGrnCatty 11-16-06, 06:34 PM Great post Todd, really appreciate the step by step instructions. What kind of tools did you use? Thx for the heads up. todd2fst4u 11-17-06, 01:30 AM i used a flat head screwdriver to aid in getting the plastic seperated from the trim and putting it back together. i used needle nose pliers to seperate the circular diagram from the metal peice. and i also used wire cutters to cut the light to the correct length. here it is all lit up. http://todd.bluesubmarine.org/Cadillac/DSCN8290.JPG 2000ForrestGrnCatty 11-17-06, 05:31 PM Looks great Todd, wish I was as fortunate. I followed your steps and It wasn't hard, but the bulbs won't work. I tried both of them that came in the Radio Shack package. I did notice the wires are a lot thicker on the original bulb. Looks like I'm going to have to pay a visit to the Caddy Stealership. I went to a couple of auto parts stores and they didn't have it. Wish i could get it to work. todd2fst4u 11-17-06, 06:03 PM yes the wires are thicker on the original. strange it didnt work for you. did you make sure the wires on the bulb weren't touching? if you look in the socket the bulb goes into, it should be divided in half by a plastic barrier. it seperates positive and negative. make you have one wire in each half of the socket and make sure they arent touching. 2000ForrestGrnCatty 11-17-06, 08:16 PM You must have great eyesight, because I didn't see anything that separated the wires. I just saw a hole in the middle, with long notches on either side. Might give it another try tommorow, got frustrated and quit. Is there another type of bulb that might work? Do the wires go in the notches that are on each side of the hole? Trying to figure it out, because I tried numerous times putting it in, and when I turned on the lights, it still didn't work. The wires on the new bulb are real flimsy and bend real easy, I had to pull the bulb out and straighten out the wires. Also, is there a piece of wire that extends out of the center of the hole that the bulb goes in? From one of the pictures it looks like a wire that connects over the slots on each side of the hole. Thx Man. 2000ForrestGrnCatty 11-18-06, 06:49 PM Todd?? todd2fst4u 11-19-06, 02:30 AM there arent any other bulbs that i know of that would work as well. im sure there are tons though, i just dont know of them. yes, the wires go in the notches on either side of the hole. i didnt see any wire extending out of the hole where the bulb goes. also you dont have to turn on the lights to see if the sunroof dial light works. it should come on all the time. 2000ForrestGrnCatty 11-20-06, 07:16 PM Thx for the heads up Todd, but I just ordered the correct bulb from Cadillac for $3.95. I just didnt like how flimsy the wires were on the Radio Shack bulbs. Glad you got yours to work though. When it comes in I'll give you a shout if it worked or not. Thx again. | |
