View Full Version : Air fan stays on when car is shut off + other problems...
Hammondsix
11-15-06, 11:03 AM
It rained today.
Today i noted that the interior fan kicked on more immideately than usual. And when i arrived at my destination the fan kept running when i shut the car off. It seemed to be coming out of the defroster vents only. I left the car for about 5 mins and the came back to see if it had shut off. No luck. I pulled the fuse as a temporary fix so it wouldnt drain the battery. Here are some of the other problems i have.
The ac drain fell of leaving alot of the wiring wet a while ago.
A metal pipe went through the window on the PAX side and now there is a space between the mindow and outside rubber strip letting water in the door and drains out on the ground.
the interior light does not come off when shutting the door.
the memory seats dont work
trunk pull down is inoperative
and now the defroster fan stays on
Can anybody help?
Hammondsix
11-16-06, 09:58 AM
codes are
23
123 interior light delay cirquit open or shorted to grnd
125courtesy light open or shorted to grnd
131pass key telltale open or shorted to grnd
Thanks
