View Full Version : Base stereo and Sirius question....
xxpinballxx
11-14-06, 07:27 PM
Does a non bose stereo in a 04 DeVille have a hook up on the HU for sirius radio?
CadillacSTS42005
11-14-06, 07:41 PM
does it have
NO
can you get
yes
you need to remove your stock changer tho i believe.
CadillacSTS42005
11-14-06, 07:47 PM
here ya are
you owe me points now
http://cgi.ebay.com/2003-2006-CADILLAC-DEVILLE-SIRIUS-SATELLITE-RADIO_W0QQitemZ150057021949QQihZ005QQcategoryZ1092 56QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
xxpinballxx
11-14-06, 08:30 PM
I gave you some for tran earlier today..I'll owe you forever it seems. Thanks ETC!
xxpinballxx
11-14-06, 08:37 PM
another question ETC....I have a sirius S50 and dock and all that...will that hook directly into the HU i have or just might as well get the hardwired unit.
CadillacSTS42005
11-14-06, 08:47 PM
i think youd need a cassette tape adapter
yuh it will work
but im an audio advisor
and i advise that the quality (which is why your buying sat radio) will be low and therefore id recommend the add on unit to the factory hu rather than the cassette adapter.
the727kid
11-15-06, 12:32 AM
...my info may be of no use, but I installed the satelite radio in my moms car with the FM modulator and it sounds decent until high volumes. I would say add-on to the factory unit so you can let everyone at the light listen to Howard Stern :-p.
xxpinballxx
11-15-06, 04:04 PM
well the s50 has a built in FM transmitter but I would sort of like to hardwire it and not use the mount. I want to mount it semi-permanent in the car.
CadillacSTS42005
11-15-06, 04:32 PM
should just buy the set up i showed you if you want it in your car with high quality
nuff said
xxpinballxx
11-17-06, 11:59 AM
I just bought it last night...is the install pretty straight forward....I use to install radios in the 90's but not too sure how much changed!
CadillacSTS42005
11-17-06, 12:05 PM
you bought the ebay set up i showed you?
guess everything worked out
if you have any problems let nicki now and ill get back im tiein up a few loose ends before i take my hiatus
