Dennis101
03-01-04, 07:18 PM
Hi. I am planing to change the front rotors and pads on my 2000 SLS. I have read a lot of confusing things, now I don't know which way to go. OEM? Slotted? Slotted and cross drilled? ??? Also what kind of pads? Brand names will be helpful. Where to buy would also give me an idea of going prices. Thanks:bouncy:
Douglass Harroun
03-01-04, 10:19 PM
Go with NAPA premium pads and the $30 chinese rotors- $150 total on fronts- work great
Dennis101
03-02-04, 07:19 PM
Thanks but no thanks. I refuse to purchase anything made in china, especially break rotors that I would be dependent on for my and my family's safty.
Douglass Harroun
03-03-04, 11:08 AM
10% of red china's GNP is due to Walmart. You are buying a lot of Chinese products . Look at the tiny "where made" notices on all your inexpensive things
Dennis101
03-03-04, 05:05 PM
I look at everything that I purchase, BEFORE I purchase, so that I Know before I buy it. It is not totally possible to stay away from everything they send here, (which puts American workers out of work), but I try to buy American made products.
Dennis101
03-03-04, 05:08 PM
All of this has nothing to do with my original question, can we stick to that. please? I could use the help.
Imprl59
03-03-04, 05:27 PM
Your car has pretty dang good brakes right from the factory. I would stick with the standard rotors unless you are drag racing the car or overtaxing the existing system in some way. Wagner makes a fine rotor that generally isn't "pre warped right out of the box" like the Chinese crap you find on the shelf at cheap parts r us. Wagners should run you about $70 each. They also make some very nice pads they call ThermoQuiet that run $50. Also note that Wagner makes severe duty rotors and pads for this car. I don't know if they can be used with the stock calipers or not.
Steve B.
Douglass Harroun
03-03-04, 09:44 PM
Steve B.
I've had great luck with NAPA Chinese rotors- in fact- I did a dial indicator on them versus American Chinese: .0005 runout, American: .005 ( that's new) and they broke in well, were nicely machined
Eldobroken
03-05-04, 05:57 PM
All of this has nothing to do with my original question, can we stick to that. please? I could use the help.A bump for you dennis. Also I am not sure does anyone know the differerence between slotted and cross drilled or a combo of both. I have been hearing that a slotted and cross drilled do not have enough surface area so race car drivers have stopped using them. Looking for an alternitave for stock breaks due to driving in rush hour traffic in NY which has multiple fast stops from 55 to 0 for extended periods. This does warp stock rotors fairly quick. Thanks in advance for any one with experience in this area.
with brakes you dont want to skimp on many things, but power slot if a good place to buy rotors, or brembo. but go with slotted rotors if you have the choice of slotted or slotted and drilled.
drilled rotors have a tendancy to crack around the holes, sometimes its just better to go with normal rotors, and slotted does tend to eat pads. and always when installing rotors dont be hard on them first 10 miles so you do not warp them.
