: How to Shut off DRLs (and add digital coolant temp and speedo in the dic)
CadillacSTS42005
11-08-06, 09:02 PM
Mods Please STICKY!!!!
NOTES
THIS ONLY WORKS FOR THE FOLLOWING MODELS!!!
96-02 Eldorado, ETC, ESC
96-97 Seville, STS, SLS
96-99 Deville, Concourse, DeElegance
~~~~~TO ADD COOLANT AND MPH DIC MESSAGE~~~~~
1) Press the OFF and PASS WARMER (referred to from here as WARMER) buttons simultaneously to enter diagnostic mode.
2) Let the system read any codes it has stored. You will ultimately be presented with "PCM?". You will answer with the fan speed control button. UP = yes and DOWN = no.
3) Press DOWN until you are presented with "IPC?". On mine, it's the very next prompt. When you get to the "IPC?" prompt, press UP to enter the IPC area (Instrument Panel Cluster).
4) Press DOWN until you are presented with "IPC OVERRIDE?". Press UP to enter the override area.
5) Scroll down (with the DOWN button) until you get to Option E. Wait a second or two, and the override value will appear to the right where the TRIP ODOMETER normally reads. Yours will probably read "43". That's what mine read when I first did this.
Below are the Option E values:
- Coolant Temp message (64)
- Battery Volts message (32)
- Engine RPM message (16)
- Avg Mph message (8)
- Mph message (4)
- Fuel Used message (2)
- Inst Mpg message (1)
The stock displays (for analog E/K displays) are Battery Volts, Avg Mph, Fuel Used, and Inst Mpg, for a total value of "43".
6) Use the WARMER button to increment the value of the override. In this case, we want to add Coolant Temp, so we're going to add "64" to "43", or "107". Press the WARMER button repeatedly to increment the value from "43" to "107".
If you make a mistake, you can decrement the value by pressing the COOLER button.
7) To permanently save the new value, hold the FRONT DEFROST and the A/C buttons simultaneously until the new override value flashes once.
8) You're done. Press OFF repeatedly to "back out" of the diagnostic system. You'll probably need to press OFF 5 or 6 times to get out of the deep "menu structure" you're in now.
Now, the coolant temp (in units specified) should be one "stop" along the revolving door we call the DIC. If you are in metric units, the coolant temp will read in *C. If you are in standard units, it'll read in *F.
~~~~~TO SHUT OFF DRLS~~~~~
1-4 FOLLOW ABOVE DIRECTIONS!!!
5) Scroll down (with the DOWN button) until you get to Option C. Wait a second or two, and the override value will appear to the right where the TRIP ODOMETER normally reads.
Below are the Option C values:
IPS03 Option C
- RSS installed (128)
-Premium Unleaded Fuel Only -
-Graphic supression (digital) (64)
-Daytime running lamps enabled (32)
-Cellular Telephone Installed (16)
-BTSI message suppression (4)
-Options not set (2)
-FUEL LEVEL LOW message suppresion (1)
6) Use the COOLER button to decrease the value of the override. In this case, we want to remove the DRLs so subtract your number by 32
If you make a mistake, you can decrement the value by pressing the WARMER button.
NOTE!!!!
in order for your drls to ACTUALLY BE OFF your twilight must be pushed all the way to the left and your fog lights (when applicable) must be off as well!!!
HOPE THIS HELPS
ETC97
CadillacSTS42005
11-09-06, 02:22 PM
heres all the option values in the event anyone wants to play with them for any reason
IPS01 Option A
-Universal Theft Deterrent enabled (8)
-Personalization / Memory Installed (4)
-Interior Purge enabled (1)
IPS02 OPtion B ( EXport Country)
-Eropean Economic Community (EEC) (16)
-Japan (8)
-Saudi Arabia (4)
-Canada (2)
-Norway/ Sweden (1)
IPS03 Option C
-RSS installed (128)
-Premium Unleaded Fuel Only Graphic supression [DIGITAL ONLY] (64)
IPS04 Option D (HVAC Options)
-Afterblow enabled (128)
-De-Ice Installed (64)
-Timer Recirc enabled (16)
-Dual Zone HVAC Installed (8)
Below are the Option E (DIC features)
- Engine RPM message [DIGITAL ONLY] (16)
- Mph message (4)
CadillacSTS42005
11-09-06, 03:27 PM
I Have A Sticky
Omg
Yesssssssss!!!!!
dp102288
11-12-06, 09:22 AM
Excellent info!!! Congrats.
digitalcaddie
11-13-06, 02:20 PM
I used the procedure to get the digital speedometer and coolant temp for a '97 SLS...it worked fine. I wonder why Cadillac didn't include those options in the factory setup?? I prolly won't ever use the speedometer feature, but I really like knowing exactly what temp the coolant is at. Nice post.
CadillacSTS42005
11-13-06, 06:09 PM
it wasnt really supposed to be for the Eldo and Seville
this was on the Deville which had a digital speedo and no coolant gauge
Its cheaper and easier to use the same programming and adjust it so they had those features on for the Deville by default and off on the Eldo and Seville
Barrister_07101
11-28-06, 12:06 AM
...tech tips is not for questions, refer to the sticky - urbanski
diamond59
10-14-07, 10:59 PM
I used the procedure to get the Shut off DRLS and it works fine. My problem is now I'm getting a message saying; "option not set."
Thank you.
promp3
12-21-07, 09:52 AM
its much better to just remove the drl fuse when you set the ips to disable the drl's you loose the automatic headlight and twilight sentenel feature.
on my 97 deville it was under the hood. its a red one what ever amp that is.
bbrewer5
12-22-07, 04:48 AM
on my 97 eldo my twighlight/auto headlight function still works like its supposed to and i have turned my drl's off via DIC.
Talamant3z
03-20-09, 11:02 AM
ok i got the coolant temp added but how do i add the speedo ?
ThumperPup
04-05-09, 10:18 AM
is there any way to get the Digital coolant temp to show up on the 2000 seville
C0RSA1R
04-13-09, 10:03 PM
I mentioned this before, but since this is more frequently visited than the other thread, I'll alos put the pics here. I have a 1998 Eldorado Touring Coupe, which did not originally come with a digital speedo or coolant temp gauge. Using the procedures outlined here, I got them both. Was going for the Tach too, but decided I would never need it.
http://www.cadillacforums.com/forums/picture.php?albumid=254&pictureid=3172
http://www.cadillacforums.com/forums/picture.php?albumid=254&pictureid=3171
Both work exactly as they should while driving, and it is really cool to see the exact temperature of the engine. The Speedo is obviously redundant, but I do like setting the cruise control a little high, so this let's me get exactly the margin over the speed limit that I'm looking for.
Chris Luongo
05-30-09, 12:48 PM
I'm having a small problem with this.
1996 Deville doesn't seem to have a button labeled A/C in the panel. I've tried pressing Front Defrost in together with various other buttons with no luck.
Exactly which two buttons should I be pressing together to save the new override value?
Chris Luongo
06-10-09, 09:54 AM
I figured out the answer to my own question.
The two buttons that need to be held in are the "front defrost" (NOT "defog") and the "AUTO/ECON" button.
They need to be held together for at least five seconds. Be sure not to release them until that number in the trip meter flashes.
Chris Luongo
06-10-09, 09:57 AM
Also wanted to add that at least for my '96 Deville, all of the other options in the list work very well!
I was successfully able to:
1: Disable DRLs. Twilight Sentinel is still 100% functional.
2. Supress BTSI message. The dash no longer displays the "depress brake to shift from park" message at startup.
3. Enable factory security system. My Deville apparently didn't have the $300 optional factory alarm, but all the equipment is in place. As soon as I added the override code, I've got a fully functional alarm now!
JHowdy
09-11-13, 07:30 AM
Although this is an ooold thread I say: thanks a million!!!
I have a 1997 STS that was originally imported to Germany but nowadays lives it's new youth in Finland with only 144.000km (89tml). I bought this car one month ago and was very disappointed to find out that the speedometer showed about 10% too high. This being my sixth American automobile in a row (I've had two Plymouths, two Chryslers and two Cadillacs) and never ever before had I seen such an inaccurate speedometer - not even in those 1960's Plymouths.
Well, I first changed the IPS05 Option E (DIC features) mentioned earlier in the opening post to get the digital km/h reading. That proved to show the same value as the "analog" speedo. So, nothing wrong with the analog meter.
Next thing I changed the IPS02 OPtion B (Export Country) from 16 (EEC) to 2 (Canada). I first tried this a couple of times with the car parked safely and then went to motor way, engaged the cruise control at about 2000-2100RPM with the speedo showing 108km/h with Export country option EEC (16) and then changed it to Canada (2). The speedometer (both digital and analog) readings dropped down to 100km/h. Boy, am I happy now! Now the speedo error is reduced to the normal 2..3km/h (1..2mph) that I've been familiar with in my earlier American cars.
It's a well known fact that the speedometers in most European and Japanese make cars show that extra 10% - what the heck for, I just wonder? :cookoo: - but I was very surprised to find out that even an American car manufacturer had gone into that international idiocy.
So thanks again for this tip! I'll yet have to check that my lights act normally (more or less according to the Finnish legislation) and if they do, I'll stick to Canada from now on. I tried the Sweden/Norway (1) option also but that gave me the obligatory DRL feature that I do not like.
PS. I did not get the digital Engine RPM message although I set the IPS05 Option E (DIC features) to 127. But that's a minor flaw :).
eldoedwardo
02-15-16, 03:08 PM
thanks for the sticky on DIC values. I changed my engine temp last year now I want to add MPH (4) and RPM (16). I should
indicate I have a '99 eldo base. My question is should I do these one at a time , then back out and do the other or may I set them both at the same time by adding the values (20).
thanks ,ED
andyoww
02-16-16, 03:07 AM
If you add one, back out, then add the other, essentially, you are adding 20.
You might as well add them both at the same time to save yourself a few steps.
