View Full Version : Plugs And Wires
stevebuick23
11-07-06, 09:23 PM
Equals a happy northstar driver! Woot. NGK plugs, and wires, massive improvement in throttle response, gas mileage, and overall performance. Also no misfire at startup! Recommended highly.
1badcaddy
11-07-06, 10:00 PM
Soo you're telling me that you aren't running A/C Delco plugs and wires? That is frowned upon here. lol!
I'm interested. What part #'s you got for us?
MashBill
11-08-06, 03:33 PM
I too am a sinner! I am running NGK TR55IX Iridium plugs on my '01 DTS. Runs better than the stock plugs, which by the way, were Denso not Delco.
I_Finally_Have_A_Cad
11-08-06, 03:38 PM
This isn't going to turn into one of those "The Earth round and not flat?" things is it? If so, I'll be mad I just spend so much on delco.
1badcaddy
11-08-06, 03:55 PM
The Earth is FLAT I tell you. I'm not brand Loyal so NGK is probably what I'll get and the Delco wires will have to work since Magnacore/Accel/etc..don't make specific sets for our cars unless somebody knows of a set that will work.
eldorado1
11-08-06, 04:15 PM
magnacor makes a set for the N*...
http://www.alamomotorsports.com/Magnecor/mag_cadillac.html
11-08-06, 10:09 PM
Those prices are much higher than delco.
eldorado1
11-09-06, 10:43 AM
Yeah, but the red plug wires are worth at least 20hp
1badcaddy
11-09-06, 02:59 PM
Yeah right. But if you mixed those low resistance high voltage wires with a set of Accels 45k volt coil packs and some corectly gapped NGK iridium plugs and had it tuned with Westers chip it could be good for over 40hp at the crank. Mind you that is all the previous parts and the chip combined. Maybe even more power is a possibilty with a good dyno tune but we will have to see on that one.
EcSTSatic
11-09-06, 03:12 PM
They have a lifetime warranty and you get some cool stickers too! I had them on my TurboCoupe.
http://www.magnecor.com/magnecor1/images/mag_spark.gif
eldorado1
11-09-06, 04:34 PM
Stickers? Oh man.... then scratch that... the red plug wires and stickers are worth at least 40hp combined.
Ranger
11-09-06, 05:38 PM
Can't vouch for the stickers but A/C Delco wires have a lifetime warranty also.
GreenMachine
11-10-06, 05:30 PM
Might not be the brand switch in plugs...might just be the new plugs that make the engine feel better :)
Also when doing your "plug wire inspection" to check them for resistance, you can order individual plug wires from the dealership. Cost varies by wire but if you only have two bad ones, 20 bucks is better than 100 or more for the full set.
stevebuick23
11-12-06, 10:24 AM
I'm using Napa brand wires, lifetime warrenty, $110 canadian, couldn't go wrong. Plugs were G-power platinums, 2 for $7.65.
Guess how far the gap had opened up on my old plugs? I really should take a picture. They are 2 tenth's bigger than my new properly gapped ones. :)
samm
02-05-07, 06:03 PM
so, the link to that list of cadillac wires available by magnecor didn't include my 02 sts... does this mean they don't make them for my 02 sts or i should use the 98-99 seville wires they do supply?
eldorado1
02-05-07, 06:09 PM
Umm... you don't have plug wires.
krimson_cardnal
02-05-07, 06:29 PM
Orignal OEM parts. AC Delco all way round... end of discussion. K_C
samm
02-05-07, 06:38 PM
WHAT?!?!?!?!?!?!?!?!
i thought the engine compartment looked a little cleaner....
Ranger
02-05-07, 07:46 PM
2000 Northstars went to COP (Coil On Plug) ignition. No wires.
