View Full Version : After market HU wire help.....Please!
nctrader
11-05-06, 04:47 PM
Trying to install a Eclipse CD200. Got everything done except having trouble with one wire. I need to wire from the Eclipse to the car ACC position, which is 12 V switched. I am not sure which wire to use. The 12 V fused constant voltage is OK. I could use some help, please. I am replaceing a OEM non-Bose unit, which has a 15 pin harness connector.
Thanks
the727kid
11-05-06, 07:07 PM
Get a wiring harness. But if you don't want to, it's the red wire.
nctrader
11-05-06, 09:35 PM
Nope. There is no red wire on the OEM harness. I did connect the 12V switched line, and the 12 V fused line from the Eclispe unit, to the orignal equipment 12 V switchec orange wire, and it works. I could not find a 12 V switched lead on the OEM harness. Guess this will work.
THanks anyway
