View Full Version : Looking for Timesert Kit
jholland
10-23-06, 03:59 PM
I'm doing the headgaskets on a 97 N* and need the timesert kit. Has anyone got a used one?. Looked on ebay and only saw a new one. There was a guy on ebay claiming he had a better solution several months ago but I locate him now.
MUGSANDLUKE
10-24-06, 12:32 PM
I doubt you will find a used kit since once you install the timeserts themselves there is only the allignment and drilling parts left over. You would be better off getting the whole kit. Go to ++ TIME-SERT Threaded inserts threaded for stripped threads, threaded inserts, thread repair , stripped sparkplugs, sparkplug blowouts, threaded inserts threaded, repair stripped threads, stripped threads, inserts threaded inserts. (http://www.timesert.com) and you will find out where to buy the kit.
zonie77
10-24-06, 02:40 PM
There are used kits available. The drill bit and tap should last for hundreds of uses. Just order the inserts you need.
jholland
10-24-06, 03:23 PM
I can't seem to find a used kit. I located fasteners at Wurth USA. They want 500.00 for the kit. Seems obsurd but then again once you accept the obsurdity of head bolts falling out of a supposedly quality engine I guess I shouldn't mind.
