: radiator with holes
capn
02-25-04, 08:15 PM
Hey all
recently i have found out that my radiator has an internal leak and i need to buy a new radiator, where is a good and reputable place to buy from?
capn
Aurora By Olds
02-25-04, 08:22 PM
My '95 service manual shows the radiator as fully servicable. You may want to find a shop that "rebuilds" them. I know there are a few around here who can do it for much less than new.
capn
02-25-04, 08:51 PM
well i would rather buy a new one b/c this has like an internal leak, and more like piece of mind ya know
Lawrence
02-26-04, 11:32 AM
Personally I would use the GM PN. $294.82 at www.partszoneonline.com You should never have to replace it again. If you do go aftermarket go with the Modine. I have had bad luck with all the others.
zonie77
02-26-04, 01:30 PM
I don't have a problem going aftermarket but if it's aluminum only replace with aluminum.
I got my last one from Radiator barn. Cheaper, name brand, fast delivery. I looked at 95 STS's on several sites. From $178 to 205. Your choice.
http://dev.autocoolradiators.com/
http://www.radiatorbarn.com/main.asp
http://www.discountradiators.com/
Or do a search on yahoo. These all show the same pn.
BeelzeBob
02-26-04, 05:54 PM
Hey all
capn
An "internal leak" implies that one of the oil coolers is leaking internally..???
If so, the end tank and the cooler is readily replaceable at home. The end tank and cooler is available as a separate replaceable part and the end tank just crimps in place with tabs that are easily un-bent and re-crimped with simple pliers.
capn
02-28-04, 12:03 PM
what i mean by internal leak is that i can not visibly see the leak but i can see where it is spraying and getting other parts wet, like its in the middle of the radiator
80greyhound
02-28-04, 05:00 PM
Hate to go off subject here, am I to assume the '98 Eldo with a 4.6 has no reserve tank for the radiator? All I can find is the main radiator cap. Do I just add the coolant straight into that?
Lawrence
02-28-04, 10:58 PM
That's right. 1 1/2-2"s below the neck.
