I have an 05, non Nav, non 5.1 system. I have gone through 4 subs and really think the Bose subwoofer is worthless. I was wondering if anyone has changed there deck speaker to an aftermarket one?
I have read the threads on adding subs, but I do not want to alter the look nor loose the trunk space because I use the car to travel in. I just want to see if I can hang an aftermarket speaker in the place of the bose sub without mods and without adding an aftermarket amp or speaker box..
Thanks in advance
yourgmsolutions
10-09-06, 04:44 PM
one of the options.
search internet or local stereo shops for a "free air subwoofers"
this type of subwoofers don't require enclosure (speaker box)
one of the options.
I was more wondering if anyone had done it. The factory system is ok, but as soon as you accelerate the bass comes down, sitting at a complete stop the sub hits alot harder.
Check it out next time you are driving, just turn the bass all the way up and listen to a son that has consistent bass notes and then drive off, the tone will change..
yourgmsolutions
10-14-06, 06:28 PM
I think you should check audio setting on you nav radio.
and posibly read from navigation book manual what each of those settings do.
it may have a lot to do with it.
I do not have a Nav system, or a 5.1.. It is the normal stereo.. Any one know the watts it puts out?
I will look through the forum i think we went over this once before
Spddemon
05-08-07, 09:33 PM
i have the same issue with mine... I have been doing a lot of research and can't find a solid resolution. A few options...
1. Rebuild the rear deck for a custom enclosure(the most expensive but cleanest)
2. Look into putting an MTX - Free Air Marine sub. it operates at 200 RMS which is as good as most enclusre subs.
3. another option is because the stock sub is so bad, put in a regular enclosure sub in the deck, but find one that has a very high minimum enclosure size. It should still hit harder than the stock but will not be too overpowering.
4. take out the spare tire and put a quality 12' in its place.
I am leaning towards the marine speaker, but becuase of the magnet it will be about 3-4 inches longer and be visible within the trunk.
