: Coolant Change
Yaemish
02-24-04, 08:53 AM
I was going to get my coolant changed at Vavoline, their website indicates that they use Zerex 5/100 Coolant. Is it safe to have them put this stuff in a 96 Eldorado?
http://www.vioc.com/serv_cooling_zerex100.asp
97Deville
02-24-04, 10:16 AM
You dont mention the coolent you are using now. If you've got the orange Delco stuff now, it would be better to replace it with the same.
Yaemish
02-24-04, 10:34 AM
I don't know whats in there now, I would assume that its the Orange (thats the long life right?)
Eldobroken
02-24-04, 10:45 AM
Hi it usually will say Dex Cool tested or i know with the Prestone it is in a silver container that says for use in GM dex cool engines.
BeelzeBob
02-25-04, 02:56 PM
You should have the DexCool coolant in your engine. It was originally made by Texaco. I would stick with Texaco DexCool, personally. I know that all the other suppliers claim that their long life coolants are compatible and such...but....I KNOW that the Texaco DexCool is compatible because they are the OEM supplier.
