View Full Version : TC and ABS problems
bigj2309
09-29-06, 05:11 PM
I have a 98 STS with trouble codes listed below.
C1716 R front dampener short to ground
C1743 Speed signal Fault
C1780 Loss of steering position signal
C1783 ICCS2 L output short circuit signal
C1785 ICCS2 R output short circuit signal
I was wondering if anyone knew what more specifically is wrong and/or where the speed sennsor is at or where the steering postion sensor is? I assume they are all related to one problem because they all came on at the same time.
Also I have code U1255 Serial Data LIne Malfunction
Am I going to have to replace my EBCM and does anyone know where it is?
Any help is greatly appreciated
Thanks
JimD
09-29-06, 05:25 PM
What I would do is clear all your codes and drive the car a few miles. Check the codes again.
You are looking for repeat codes as opposed to codes that could have been set in error.
bigj2309
09-29-06, 05:27 PM
Those are the codes that have been cleared and come back several times.
JimD
09-29-06, 05:42 PM
Those five codes all have one module in common and that is the CVRSS box. Located behind the rear seat cushion on the right hand side of the car.
I would check back there for damaged wiring or a loose, corroded, or damaged connector.
