View Full Version : Seat motor issues
Tailfin
09-23-06, 06:43 AM
Okey dokey... Got an issue with the seat motor. I'm unfamiliar whether this is run on one motor and gears, 2, 3, 8 whatever...so I'm seeking help in where the problem most likely is.
Unfortunately for me, I suspect wiring of some sort, because the forward/backward movement of the seat started not working unless I had the door closed. This is driver seat, by the way. Well, now, it just won't work at all. And as luck would have it, it ceased functioning right after I let my girlfriend borrow the car. Yes, she's shorter than me...:bigroll:...sooo...I've gotten kinda used to it by tilting back and such... Anyhoo, the tilt and the up/down movement still works fine, just the forward and backward is screwed. I'd just like a leg up on just what part of the system that points to so I don't end up replacing 5 different parts before it works again.
