View Full Version : Door wont open... 83 Coupe De Ville
1990CaddyBrougham
09-22-06, 08:22 PM
On this new 83 coupe i just got... the passenger side door wont open.
From the outside the handle is frozen
and from the inside the handle fells like its loose and not catching/pulling anything.
Is there even a way to take the door panel off with the door closed???
:crybaby:
Thanks
pimpin88
09-22-06, 10:47 PM
You should be able to get the door panel off with the door shut. It's just a PITA!! I had to do it with my 92 buick roadmaster. I eventually got it off, but man. Not fun.
Benzilla
09-22-06, 10:50 PM
Maybe Sal knows, didn't his '79 have the same problem?
eldorado99
09-23-06, 03:14 PM
I had that problem. For me it was just a matter of sticking oil can with a long thin tube down the window slot and using a flashlight, I was able to oil the door handle mechanism and was then able to free it up. I don't know if you could do that on an '83 though. Good luck!
1990CaddyBrougham
09-24-06, 03:44 AM
YEP!!! All it needed was some LUBE-RA-CATION
