: Outside Temp Display not working
09-21-06, 01:59 PM
Recently the outside temp display stopped working. It flashes at 32 degrees in the morning but nothing comes on after that. Could it be a fuse problem? Is it easy to replace?
09-22-06, 08:53 PM
Smells like a sensor problem - either the sensor itself might have gone south or else maybe the connection to the sensor has shorted, broken, or lost continuity. Just a guess. That's where I'd start.
09-24-06, 10:16 PM
Mine went blank about two months ago,fan works and i can control the speed and the mode rear defrogger is working too,just no disply but the bad part is i cant turn the heat on it is kindda stuck on 25-30 degrees celcius but winter is round the corner so i have taken the climate control unit aprart today,found one in the junk yard for 200 bucks,lets see if it is the unit itself or not i have checked all the conncetions at the back,if you guys have any other idea that might save me 200 bucks.
10-02-06, 05:02 PM
Changed the unit today,bought it off a junk yard for 175 bucks,works like a champ now.
