: Help!!!
mp2
02-20-04, 12:15 AM
Can someone tell me how to get my eldorado to go over 115mph its very fustrating when im tryin to run with camero,s and such:banghead:
BeelzeBob
02-20-04, 12:26 PM
Open the drivers door and look at the tag that specifies the recommended tire pressure that is located inside the door jamb. Read it and find out what the factory installed tire spec was. That will tell you what speed limiter is on the car based on the OEM tires. The vehicles are limited to the speed that the OEM tires were rated at. I suspect that you are running into the vehicle speed limiter for a lower speed rated tire. Not much you can do about it.....except go buy an ETC with Z rated tires from the factory...those have no speed limiter. Thank the trial lawyers for frivilous lawsuits that caused the speed limiters to be installed.
