View Full Version : trunk key
Tyrannous
09-18-06, 11:48 AM
i own a 1973 cadillac with a weatherstripping leaking problem in the trunk.... my main problem is someone stole my main set of keys (w/ cadillac keychain) and now i have no trunk key, and water is quickly collecting in the trunk. Can someone help me find a new key for my trunk, or point me in the right direction? :crybaby:
GEORGE J UHLER
09-18-06, 12:33 PM
The original keys had a key code that was stamped on a knock-out portion of the key. It was to be knocked-out of the key and the knock-out given to the original buyer, who, in turn, was suppose to put the knock-outs in a safe place in case the keys were lost. Then a new set could be made from the code. You don't have the coded knock-outs do you?
Otherwise, check with a Cadillac dealer on this one see if they can help. They may wind-up suggesting a locksmith however.
Rick186
09-18-06, 11:14 PM
Dealer supposedly can get a trunk key cut by info from VIN.
GM keeps the data on file.
I had my ignition key done that way (that's more difficult since they need verification of ownership for the "chip" on the key).
Tyrannous
09-19-06, 11:13 AM
thanks for the ideas, i dont have access to the knock out keys, ill check with the dealer!
brougham
09-19-06, 06:04 PM
A locksmith should be able to make a new key for it. It's probably too old for the dealer to be able to do it unless you already have a key for them to copy but who knows maybe they can.
codewize
09-20-06, 12:02 AM
Locksmiths will usually drill the lock on a car and tell you to replace it. Probably not a big expense but I don't think they're going to cut a key from it. Having some locksmithing experience I know that's not an easy task.
Maybe if they're good but it's getting harder and harder to find good help.
carnut
09-21-06, 06:49 PM
Doesn't this car have a remote trunk button in the glove box? A yellow button, size of a dime?
Old Fleetwood
09-21-06, 10:05 PM
Usually, Yes. At least my '95 Fleetwood does.
(I'm actually Rick186 but had to sneak in and re-register as the name above since something in the software tonite wouldn't let me in.)
Incidentally, alongside that yellow button is that handy-dandy switch for shutting off the traction control. But it also kills the ABS. Everything comes back on when you shut down the ignition and re-start, however.
That shut-off is good for:
> rocking out of mud or snow,
> the drag strip (or so I'm told, of course)
codewize
09-21-06, 10:47 PM
I turned off the TC in my 93 Brougham to rock out of a mud snow mix. It's cost me $1500 in repairs to the rear end. Actually it was a full rebuild, axle bearings and all.
Rick186
09-21-06, 11:10 PM
Ouch!
codewize
09-23-06, 12:02 AM
Yeah, when the manual says DON'T DISABLE THE TRACTION CONTROL SYSTEM, YOU MAY DAMAGE YOU CAR. It's not because they don't want you burning out. You really will damage the car.
