View Full Version : help
caddyrod
02-18-04, 10:00 PM
I am trying to remove the distributor out of a 1985 fleetwood brougham RWD and I cannot find the the bolt that holds it in place where is it located?
FASSTWOOD
02-18-04, 10:35 PM
the best way to get it is with a distributor wrench 13mm or 1/2 inch. Its on the left side of the distributor (if your sitting in the car). It is a 4100 right?
caddyrod
02-19-04, 07:21 AM
yes this is a 4100. ok I will look on the left sideof the distributor(if iam sitting in the car). Thank you for the info.
caddyrod
02-25-04, 02:26 PM
Igot the nut off but it was a 15mm. A lot of the 1985 4100 have 15mm nuts with a clamp.
FASSTWOOD
02-25-04, 09:05 PM
Well at least you got it off :rolleyes: What are you trying to do anyway.
